Hy to every one, My mill start to move and sound great, but I have 2
problems,
1. Limit switch, I conect 5 limit in serial to IO17 , I
give 3.3v to them , so when one of them open the mill stops, The problem is that
the mill stops 10 times in a mill process and limit does not swich to on,
I try to use 5V and an Optocopler board and
same result
I see that in industrial machines use 24v to sensor, and then to optocupler
board or relay,
Which is the best way to conect the limit?
2. Close loop, I install a digital scale to the mill and conected to
Kflop, when I conect them the measured is wrong, I mean if I say G0 x150, it
moves X 162 or so. If I do not use the scales the table moves correctly. when I
conect the scales I just change in Config flash in every axis, input – encoder,
output --- CL step
Regads
